Hi,
I'm a first time PC builder and having some probs with the CD-R and also installing the Win98SE OS.
* Using the startup diskette, the ramdisk gets created but the cd-r driver only gets loaded maybe 10% of time. The other 90%, I'm getting a "File not found" message and the cd-r driver doesn't get loaded. When I recreate the startup diskette on my existing pc, I'm sometimes successful loading the driver - but the startup diskette seems to be only one-time use, and the next time I try it get the file not found message again.
* Those few times I have loaded the cd-r drivers, I have tried unsuccessfully to install the Win98. Have tried running setup.exe from the CD, and also copying the files to the c: drive and running it. Encountered various probs, including: hang-ups, disk errors during scandisk (after fixing them, more hang ups), messages about corrupt command.com and .cab files.
If it's relevant, specs: Soyo KT 333 Ultra mobo, Athlon 2000 XP cpu, 80GB HD (only one partition), Lite-On CDRW. Have checked all switches and connections and they seem ok. Have not yet flashed the BIOS. Have re-formatted and re-partioned multiple times.
If anyone has any ideas I'd really be grateful -- I'm nearly at the end of my rope! Thanks in advance for your help.
Dess
Dess
