- Aug 7, 2001
- italy /forlì
the celeron 800 in my sign.....batboy said:Something like that might just work. I would not use superglue though. I might try clear fingernail polish or something similar like that. You would still have to connect VID3 and VSS pins like you said, but isolating VID1 would give you 1.95v not 1.8v like you figured. However, if you isolated VID2 (plus connected VID3 and VSS), that would give you 1.85v, which just might work ok if you have good cooling. If you didn't get VID2 completely isolated though, you'd be at 2.05v, so be careful. This is a good idea, we just have to think it out carefully to make it work. Of course, you could remove the VID2 pin, but that's very drastic and I don't like that idea. Maybe other members can help out with ideas. Good luck.
with the mod pin is @2.05 without problem.....
