Installed my first CM 212 Evo and have a few questions for those more experienced installing these units:
1) Though my screws are tight, if I grab the heatsink, I can still gently twist the HS from side to side. Is this normal? I removed it and made sure the pin was seated in the base of the HS and I still had play after I had tightened all 4 screws.
2) Stock i5-3570K is running around 38-40 C idle, P95 Blend 65-68 C and hit 72 C once in a while. IBT (Std) 72-76 C.
My goal is to OC this to around 4.3 so could use some input...
Many thanks ahead of time!
