- Feb 25, 2003
- Charleston, SC
Hello,
Well I am in to my next build and came upon an issue. When I install the Corsair H100i Pro in the CM Trooper SE, I find that the top filter will no longer go back into place. The problem stems from the screw head clearance. Has anyone encounter this as well? If so, did you find a solution?... Besides not using the top filter.
Kind regards, Dean.
Kind regards, Dean.
