Hi everyone
I'd like to get some opinions on a mini itx pc I'm going to build.
The main difficulty here is that it has to be very compact and horizontal. So for the case, I chose Phanteks evolv shift air. From everything I've seen - I guess this one will suit best.
other specs:
-ROG STRIX Z390-I GAMING
-Intel Core i9-9900 or Intel Core i7-9700K
-Noctua NH-L9x65 or Noctua NH-L9i. Yep Air cooling. And if I understand correctly, it has to be a low profile one. But maybe Noctua NH-C14S could fit too.
-old gtx 980ti will do for now
-Samsung MZ-V7S2T0BW (m.2 970 evo plus 2tb) and one more later
-32Gb(16+16) DDR4 3600MHz G.Skill Sniper X
-Seasonic FOCUS SGX 650W
This setup has no chance to be good or anywhere close if you put it into the ITX case. Any replacement from 10k series will be probably even worse if it will be rated at 95W TDP+.
1. Intel 9700/9900 heat up too much for ITX builds. You will see constant throttling because of heat and/or fans will run at max speed. Picking something from AMD right now will give you much better temps and better performance in everything but games that base on high CPU clock.
2. Noctua L9x65 or L9i are designed for low power CPUs, up to 65W TDP. There is no way it could handle anything 95W TDP from Intel which is in real 200W+ during load. I will only give you an example. Run 9700K so 95W TDP on Noctua top coolers and you will see 90°C+. Now think what will happen if you install it in a small case with limited airflow.
3. GTX980Ti is not a good idea for ITX build because of the same reason as above. I don't recommend any graphics card above 160W TDP for ITX builds. Think that wattage given by manufacturers is actually max GPU power only so if you take "170W card" then it will give around 200-220W in total under full load.
4. Check how M.2 SSD will be installed. On many motherboards, M.2 sockets on the back of the motherboard with a limited airflow cause SSD to overheat and throttle all the time.
5. Phanteks Evolv Shift Air seems improved but I had a quite bad experience with the non-air version. I assume you want this case because of how it can stand horizontally but something like NZXT H210 would be a much better option for ITX as you can install a much better/larger CPU cooler and provide a better airflow.
Sadly, there are barely any small and good ITX cases that offer reasonable airflow for both, CPU and gfx card. Most ITX gaming cases are not much smaller than a mATX or small ATX towers.
6. I recommend high-quality SFX PSU for small builds. For that, you can get a $2 ATX to SFX bracket which often comes with the PSU. SFX PSUs are smaller, have shorter cables so they are easier to install and won't cause additional problems with the airflow. Something like Corsair SF600 should be enough.
My suggestion is to find some more space for the PC and do it right.
