- Aug 17, 2009
Alright I came to this website after others have failed me on this problem.
Before we begin, here is a screen-shot of the relevant part of my BIOS at factory default settings (except for the RAM timings)
Yes, I change the performance enhancer to Standard before doing anything. Turbo is just the factory default.
Here's my situation: I have an Intel Core 2 Duo E8400 and a Gigabyte P35-S3G MB. I have heard that the E8400 was a dream to OC but I have to disagree.
I can bring the CPU speed up just a few MHz but when I restart, the computer fails to POST* and resets all BIOS settings to factory (which after several dozen times get REALLLY annoying).
Keep in mind I am tuning back the memory multiplier to keep the RAM speed well below it's rated 1066 MHz. I have read on this forum that I should have a 1:1 ratio but that's impossible. The lowest ratio I can choose from is 2:1.
Now in my naive opinion, I don't think it's the CPU's fault. Because I did this...
As you can see, The CPU's speed is still at 3GHz and the RAM is well below the max allowed. Also, I have all voltages set to AUTO for the MB to decide what to use. And even this setup doesn't POST!!! What could possibly be wrong here?
It's no longer about the OCing to me. Now it's personal. This is my very first home-built PC and now I know there is something wrong with it and I want to find out what.
here are some trimmed down specs generated by CPU-Z that may be of use.
* I am not sure if I am using the phrase "fails to POST" correctly. The computer turns on, beeps once (which means a successful POST right?), shows me the Gigabyte logo screen, and then shuts off and resets settings.
Code:
CPU-Z version 1.47
Processors Information
Processor 1 (ID = 0)
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name Intel Core 2 Duo E8400
Codename Wolfdale
Specification Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz
Package Socket 775 LGA (platform ID = 0h)
CPUID 6.7.6
Extended CPUID 6.17
Core Stepping C0
Technology 45 nm
Core Speed 2009.9 MHz (6.0 x 335.0 MHz)
Rated Bus speed 1340.0 MHz
Stock frequency 3000 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T
L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 6144 KBytes, 24-way set associative, 64-byte line size
FID/VID Control yes
FID range 6.0x - 9.0x
max VID 1.225 V
Features XD, VT
Chipset
Northbridge Intel P35/G33/G31 rev. A2
Southbridge Intel 82801IB (ICH9) rev. 02
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 4096 MBytes
Channels Dual (Symmetric)
Memory Frequency 536.0 MHz (5:8)
CAS# 5.0
RAS# to CAS# 5
RAS# Precharge 5
Cycle Time (tRAS) 15
Command Rate 2T
Memory SPD
DIMM #1
General
Memory type DDR2
Module format Regular UDIMM
Manufacturer (ID) G.Skill (7F7F7F7FCD000000)
Size 2048 MBytes
Max bandwidth PC2-6400 (400 MHz)
Part number F2-8500CL5-2GBPK
Attributes
Number of banks 2
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP yes (1 profiles)
XMP no
Timings table
Frequency (MHz) 266 400
CAS# 4.0 5.0
RAS# to CAS# delay 4 5
RAS# Precharge 4 5
TRAS 10 15
TRC 16 24
EPP profile 1 (full)
Voltage level 2.100 Volts
Address Command Rate 2T
Cycle time 1.875 ns (533.3 MHz)
tCL 5.0 clocks
tRCD 5 clocks (9.25 ns)
tRP 5 clocks (9.25 ns)
tRAS 15 clocks (28.00 ns)
tRC 48 clocks (90.00 ns)
tWR 13 clocks (24.00 ns)
DIMM #2
General
Memory type DDR2
Size 2048 MBytes
Attributes
Number of banks 2
Data width 64 bits
Correction None
XMP no
Timings table
CAS# 4.0 5.0
RAS# Precharge 4 5
TRAS 10 15
TRC 16 24
tCL 5.0 clocks
Hardware monitor
Intel Core 2 Duo E8400 hardware monitor
Temperature sensor 0 46°C (114°F) [0x36] (Core #0)
Temperature sensor 1 42°C (107°F) [0x3A] (Core #1)
Dump hardware monitor
Hardware monitor
GeForce 9600 GT hardware monitor
Temperature sensor 0 59°C (138°F) [0x3B] (GPU Core)
DMI
DMI BIOS
vendor Award Software International, Inc.
version F4
date 07/10/2008
DMI System Information
manufacturer Gigabyte Technology Co., Ltd.
product P35-S3G
version unknown
serial unknown
UUID 00000000-00000000-0000001D-7DD21D70
DMI Baseboard
vendor Gigabyte Technology Co., Ltd.
model P35-S3G
revision unknown
serial unknown
DMI System Enclosure
chassis type Desktop
chassis serial unknown
DMI Processor
manufacturer Intel
model Intel(R) Core(TM)2 Duo CPU
clock speed 3015.0 MHz
FSB speed 335.0 MHz
multiplier 9.0x
DMI Memory Controller
correction 8-bit parity
Max module size 1024 MBytes
Software
Windows Version Microsoft Windows Vista (6.1) Ultimate Edition (Build 7100)
DirectX Version 10.0
