- Dec 27, 2008
I have a TP-link Archer C9 v.1 router that does not support SMB v. 2 so I have gone into Windows 10 settings and re-enabled SMB v.1 so that I can see the other devices on my home network in the Windows File Explorer Network section. But I am concerned about the security vulnerabilities inherent in doing so. As you may know, Windows 10 updates in the past year automatically disabled SMB v.1 because of it's serious security vulnerabilities.
In contacting TP-link support via chat to inquire about SMB v. 2 support in their newer router products I get the runaround. They don't seem to be able to answer the question and are "checking with the Advanced team".
In researching this whole SMB issue on the internet forums I get the impression that it's not just TP-link that is behind the curve in this matter but other Wifi router manufacturers as well.
My question is, does anyone know of any current consumer level dual band routers that definitely support the newer SMB protocols? I'm looking to upgrade to something that supports SMB v.2 or later.
