The best way to check would be put a fan on the HS (duh!) and turn it on, if it boots and runs stable at the same speeds as before then it probably hasn't sustained any perminent damage.
probably not...how long did you run it like that for?? i think the chip is safe against damage up to about 90degs...although anywhere near that temperature aint gonna be good for it. as you can see, my rig aint exactly cool though. i wouldnt worry about it
