Alright....
Sorry I been away all week... School was kicking my rump and one of my rules is no play till all the work is finished.
I'm finally caught up now and have time to give an update.
So far this machine has been absolutely awesome! I hadn't realized how slow my old box was untill I fired this one up for the first time!
There have however been a few setbacks...
First off being my H100 was DOA. So I'm at the moment running the stock Intel heatsink and fan. Such a waste right???
A minor issue is the fact that I still need to order some sleeved extensions for some of the peripherals, as well as the EATX Leads.
(SOLVED! Needed to space the two cards apart a bit using a rubber spacer.. The one card really WAS running 20c hotter! Fans couldn't get any air.) Another issue being that the temp readings in GPU Tweak for the Asus Matrix cards are a little wonky... One card reads that it idles at 55c, while the other a more reasonable 31c... Yet the instant I switch to the GTX 580 that reads 55c most of the time, it will read about 33c for one capture, and then jump up to 55c. There are a few odd temp readings between both cards that I'm trying to straighten out, such as the card with the lower core temp reads that it's board is about 20c higher than the card that reads 55c for core temp... but to be honest... I have no clue how to go about it. I'm seriously debating at this point buying either a Mars II when they become available, or going ahead with some sort of reference card 580 and doing my custom water setup.
The last "issue" thats driving me crazy is the fact that I'm running the G19 Keyboard with the "performance meter" display... And when idling with no programs actively running the CPU meter jumps from 0% Load to about 45% load and then back to 0% load about every 2-3 seconds, but when I run process explorer, the jumping stops, and PE shows a total of less than 2% CPU utilization... I don't know if somehow I've already come across some tricky peice of malware thats able to hide it's activities when PE is running or what.... All I know is that MSE shows the system as being clean. I'm sure the performance meter on the keyboard isn't too terribly accurate anyway, but it should be better than a 43% difference and I'm 95% positive it didn't do this for the first couple of days.
If anybody has some thoughts on these issues I'd be glad to hear them!
So for right now these are the things I'm working on in my free time...
1)I'm still doing some tweaking and such regarding what processes need to be running in the background and what I can live without.
2)Waiting on the H100 to come back from RMA service so I can start playing around with overclocking the processor. Currently the only thing I've done so far is to load the XMP profile for the Dominators.
3)Trying to decide which benchmark programs to invest in... If anybody from the benchmarking team would like to chime in on that it'd be great! I'm working on hammering out my 100 posts, and would like to start getting my benchmarks done to gain membership on the team.
4)Trying to gather all the little tweaking and testing apps that are out there... I especially need something for testing the SSD and HDD's.
I've got a bunch of pictures I need to go through and organize for posting... Hopefully I can get to that in the next couple days.
For the question regarding the Vertex 3... Not so much as a single problem with it so far. Works flawlessly... However... I haven't done any research on what firmware is on it, or anything like that yet. But I will once I figure out what programs guys are using to bench the drives.
