[FONT="]. Trying AOD to work my way up to 4.0ghz. CPU temp is at 44C idle but gets to 53C on load. Must watch temp to make sure it does not go beyond 55C. 3.9 has been accomplished using AOD
I do have the FSB testing planned for the future, I just need the time for it now.
ChristmasGT:
A 64bit environment uses a higher amount of bits per a clock to do 1 calculation. As a result there is a limited speed of which a CPU can run under a 64bit environment. I have already exhausted the possibility of having 3.9ghz and 4.0ghz in Vistax64. If you want to do suicide runs, I suggest to grab Vista 32bit or XP 32bit. That is the only way your going to see higher clocks.
Update on the front page. Concludes the majority of my NB work.
So I have been over at the XS forums, along with this one, gathering informaiton on the new AM3 and 720BE. It seems that you will be able to do a much higher OC with the AM3 boards with any of the AM3 CPUs. I have been able to seen this so far with the data I have collected.
Normally it requires 1.55v to gain 3.8ghz using 720BE on AM2+
While it requires 1.375 (stock) to gain 3.8ghz using 720BE on AM3
Reason behind this?
