Pack data of 1/9/08 here... does that make mine "new"?
I am sorry i don't understand you
coretemp readings are off. why are you rmaing them?
imposter said:New e8400's will not work with coretemp.
thehacker010 said:Just so you guys know my pack date was 12/20/07, which would make it an "old" one.
harlam357 said:Pack data of 1/9/08 here... does that make mine "new"?
Your CoreTemp is reporting a 100 TjMax, while evreyone else has it at 105, which we think is correct (this also means that your temps in v0.96.1 would be 5° higher). Maybe we can go back to blaming CoreTempI too was under the impression that the temps of the E8400 were going to be lower. I ebayed my X6800 and purchased a E8400 a week ago. I had my X6800 clocked at 3.61 using the unlocked top multiplier. I have my E8400 clocked at 3.61. I am using a Synth Ninja Cooler with a SilenX 120 fan. The X6800 at 3.61 & 1.425v ran at 41 idle and this E8400 @ 3.61 & 1.25 is running at 49-50 (Readings from Core Temp .95.4) I thought my temps would be lower with this proc. than the X6800. (Also with my Bios and this E8400, and my MB it will not boot with 4GB of Ram, get the BSOD.) Not sure whats going on there. Anyone else have that happen?
These are my stock readings.. havent tried to Oc yet..
Using a 9700 LED for the HSF btw..
CPU: e8400
Batch# Q746A516
Pack Date: 01/29/08
Core Temp reads: 39c on both cores. Shifts for a second between 38c and 40c, but pretty much stays put on both cores at 39c idle.
Then I ran prime95. The temps jumped up pretty fast to about 46. Now they stay there, sometimes for a second hitting 47c. Then as I watch, about 2 hours in, they sometimes go down to 45c. Both cores are being used and at 50%.
This is my first multi-core processor, so I am not used to how they should read for temps. I am trying right now just to see if my 9700 LED is doing it's job.
Now yesterday, right after i got it together, I ran all this and I was 42c on idle and about 50c'ish about a hour and half into prime95. So the temps seem to be going down the more I let this cpu burn in.
The cores are staying pretty much equal with core temp. Sometimes they differ by 1c or 2c but its only for a few seconds running prime and then they are the same again.
Just thought I give my temps and batch/pack to see if there is a improvement in readings from earlier batches.
CoreTemp's is labeled VID, so that's essentially default vcore for that particular chip.I'm curious about my Vcore also...
Bios Setting: 1.305
Bios Reading: 1.20
Core Temp: 1.0375
CPUID Hardware Monitor: 1.19
CPUID: 1.192
Abit EQ: 1.19
What reading is correct?
I JUST received mine with a pack date of 1/29/08 SLAPL What can anyone tell me about this chip?
Throw in vdroop is why your readings are not 1.305, and apparently there's some more going into Windows. So ~1.19. If you want to be sure, throw a voltmeter on it.
