- Dec 17, 2003
- Regina, Saskatchewan
crull I think voodoomelon is right in think that each machine is diferent but also each location is different and remeber that humidity plays a hugh role in how much heat the air can absorb.
voodoomelon said:Hey.
Ok, things are a little heated up at the moment in this room, I haven't had the window open, and there has been 3 people in the 14' X 9' room for the last 2 hours. So, my temps at the moment are as follows:
Ambient room temp : 20.8*C
BIOS CPU temp: 30*C
Case temp 23.9*C
CPU Torando: 2556rpm
2x 80mm intakes
2x 80mm exhausts
1x 80mm intake blowhole over Radeon
1x 80mm exhaust top of case
My room temp is usually ranging from a chilly 15*C to a warmer 20*C, on average about 18*C i'd say.
When the room is 18*C:
BIOS CPU temp: ~ 28*C
Case temp: ~ 22*C
Crull,
Can't say I agree with that, as you can see above. I'm sure there's probably plenty of people with CPU temps lower than 10*C over ambient. I don't doubt for a second that you've done extensive testing, however have you done it on more than one machine in different locations?
The temperature outside me right now is easily -2*C. Does this count as a sort of ambient temp for this room? The insulation in this house leaves alot to be desired, hence my usual low temp of 14*C when I wake up. Also, opening my window every half hour or so when it heats up leads to a difference in air pressure. That would also affect my case temps.
I don't know what else I can say to convince you crull.
"them's my temps an' i'm stickin by 'em"
I'm just trying to highlight the differences between our setups.
itshondo said:I got a PM from a fellow Member who wanted me to make him a duct- I can't but I did send hime these instructions-
It's not hard to make-
buy a peice of plexiglass from home depot (not the thinnest plexi, one thickness up), some plastic glue, and a utility knife. The plastic glue comes with a little bottle of plastic cleaner. You can get all of this at Home Depot for about $10.00.
Measure the length and wiidth of the sp94 and then -
The overall size of this duct will be the same size as the fan you are using and the same height as well (so you can attach the fan with the cut wire holddowns like Voodoomelon did)- I just taped mine to the sides of the HS with aluminum tape.
You may have to make a few trys at the sizing- the 2 vertical sides will be exactly as wide as your fan and the 2 slanted pieces will be a little shorter ( so that when your glue the slanted pieces to the vertical pieces the overall width will be the same width as your fan)
Cut the pieces with the utility knife, scoring the plexi repeatedly along a metal ruler or straitedge. After 10 passes or so, you can flip the plexi and snap the pieces off. Then all you have to do is mark and score these pieces to the right length.
Glue the peices up on a flat surface using a small box to lean the vertical peice against, then glue the slanted peice to the vertical. Get another small box to lean the other vertical piece against and glue that to the other side of the slanted piece. Then glue up the last slanted piece bye putting it between the two vertical peices and let it dry. After it dried, I applied more glue to the joints for strength.
You can do this!
