- May 30, 2004
What kind of cooling are you using for that 4GHz overclock?
Also, you should run RMClock to see if you're throttling at that speed.
DanIdentity said:What kind of cooling are you using for that 4GHz overclock?
DanIdentity said:Also, you should run RMClock to see if you're throttling at that speed.
I couldnt agree morelarva said:If these things have 4GHz in them routinely they will be very popular.
ronaldo said:this is a great overclock...
i hope you are happy with your choice with dual-core cpu..
Welsome to the clubhyperasus said:but that AMD was such an unstable POS
The P5WD2-Premium doesn't support SLI, at least not yet.Elif Tymes said:Maybe I'm dumb(which is something I commonly hear myself called) but why 2x 6800GT W/o SLI? Are youplanning on getting it when Nvidia releases a Dual Core Chipset?
Huh? How is that possible. It COMES with a SLI bridgeHardin said:The P5WD2-Premium doesn't support SLI, at least not yet.
RangerXLT8 said:Are the only options you have for SpeedStep *Automatic* and *Disabled*? I'm experiencing this problem with my P5WD2-Premium\P4 650. On my 925XE(P5AD2-E) the options for SpeedStep where *Automatic*, *Maximum*, *Minimum* and *Disabled*. I'm hoping they will resolve this with a bios update.
Yes, this is true. However you can still use SLI because the minimum specs are 8/4Hardin said:Look at this .
The current Nvidia drivers don't support full SLI with it yet, but Asus says a BIOS update will improve performance.
The main slot remains 16X in both single and dual video modes. The 2nd x16 slot can be configured as Auto, 2X, or 4X in a "semi-SLI" mode that disables the remaining x1 PCIe slots if x4 is selected. The 2 video slots are of limited use for combining video card capabilities as they are now configured. To work at all with current NVIDIA video cards, you have to use the very early (and almost impossible to find) 66.75 drivers. We verified that two video cards are recognized as SLI by the 66.75 drivers, but we could not get any current SLI-enabled games to work properly with the pair of video cards. Asus tells us that future BIOS upgrades will improve this performance. Asus also hinted that other dual video card configurations may also support the dual slots. Could this mean that ATI dual video will work on this Asus with a BIOS update when ATI releases their dual video solution?
Capt_Caveman said:What bios are you using for your P5WD2? There is a bios 0408 that will give you all of those SpeedStep options.
