I installed the new SSD one day last week. I've been wanting to start overclocking my system for a while now but am a little overwhelmed by all the information I've been reading recently. Today I read
this guide but it may be outdated, I also read
this guide,
and combed through this and watched
this video
The ultimate guide I read says to find the Max FSB, then max memory FSB, then Max clock speed.
Inside the BIOS I was able to disable all the useless features easily, but am unsure about what to do next. which settings other than those things to change and which ones to leave alone and in what order. Below is a bunch of the options i've found inside the BIOS that I know I need to understand to tweak and find a good overclock. I'm looking to hopefully gain some insight on what some of these settings should be set to to start and in what order I should be increasing them, which ones to avoid changing, and if any of the stuff i've read is outdated and no longer helpful please let me know.
processor max frequency:6300Mhz
NB Max Frequency:6200Mhz
Processor Max Voltage:1.5500V
Options available and corresponding defaults:
CPU Frequency Multipier x18.0 3600Mhz
CPU Voltage 1.3250V
NB Frequency Multiplier x10.0 2000Mhz
CPU NB Voltage 1.2250 V
HT Bus Speed Auto (Min. 200Mhz Max. 2400Mhz)
DRAM Timing Control
Voltage Control (these can be set to auto or manual but manual shows no default voltages only min and max)
DRAM Voltage (Min. 1.250V Max. 2.065V)
NB Voltage (Min. 1.110 V Max. 1.400V)
HT Voltage(Min. 1.210V Max. 1.400V)
CPU VDDA Voltage (Min. 2.56V Max. 2.70V)
PCIE VDDA Voltage (Min. 1.81V Max 1.92V)
