- Aug 20, 2003
LOL, that's a lot of fans and other goodies!
I'll double check but i think the drive cage has to be in the original position for the 5.25" bay to be in. If that is the case I think 240 and 280 is the biggest you can fit up top. 360 might push it to much. 240 might be all you could fit up front as for the 280 I believe moving the drive cage is nessisary. If you got a short enough PSU could fit a 240/280 on the bottom.I'm eyeing this case, but am having problems envisioning a custom water loop in it with a rad on the top. I have a 4x120 now but that likely won't fit. 3x140s would be nice. What kind of rad do you think you could fit on top while retaining a 5.25" optical drive?
You didn't have issues with core 1 with air cooling? Seems odd that switching cooling would cause issues. Is the clamping force that different? How does your paste job look when you take the block off?
Thanks. It's getting there just need to solve the block issue before moving forward with wire cleanup and lighting. The mess of cables... fun fun. Forgot to take a pic of the business side last night but it looks nice and clean.Looks nice. I am interested in the HDD bay setup they have here. I have three different Fractal cases and I truly love them. They are heavy as hell but you will never get case vibration from them. They are solid. Your build is looking good.
My old 290 was LOUD and hot. My 1060 and 1080ti are actually decent. The 1060s are smaller single fan setups. Get up to around 70 with 60-70% fan speed. Its noticable for noise but still quieter than the 290.2x140 would be plenty for the CPU. I like to water cool my GPUs, too, so that might necessitate another 2x140 up front. How's the noise and temps on your GPUs on air at load?
Still at a loss here on the cooler. No luck solving the cooling issue.
I mean it sounds like either they have a manufacturing defect or something else is going on. I don't see how MB thickness can really play that much of a role. When my H115i is tightened down there is absolutely zero play between the block and the CPU. Your not somehow using the wrong screws or something are you? You can put plastic washers between the screw head and the bracket that goes over the block. Ace Hardware has an amazing assortment of nuts/bolts/washers and is my go to for computer mounting hardware. But in all reality you shouldn't have to do any of that...
I see you tried washers behind the mb, did that tighten up the block so it doesn't move when the screws are tight? I mean all of my intel CPUs have had a core that ran 15-25C hotter than the rest that required a delid to fix.
Now my 1080ti... that is relatively quiet. 3 fans 50-60% I can hear it but it's not distracting by any means. Curious how it plays out in the new case since I removed the 1060 I had in the case. Least this under load mid 60s typically. With the power limiter cranked.
I've used evga Hydrocoppers for my last couple GPUs (980Ti and 580Ti). Can't get them to bust 35C on load with my water setup. Debating whether to plan for these in a Fractal setup, or just keep my Mountain Mods Pinnacle 24 rumbling.
