Hardass Senior Member Joined Nov 3, 2001 Aug 25, 2010 #1 Does anyone know the SetFSB setting for this mobo?
redduc900 Inactive Moderator Joined Dec 17, 2000 Location Portland, OR Aug 25, 2010 #2 The X58A-UD3R uses the ICS 9LPRS914EKLF clock generator, same as the X58A-UD7.
OP Hardass Senior Member Joined Nov 3, 2001 Aug 25, 2010 Thread Starter #3 redduc900 said: The X58A-UD3R uses the ICS 9LPRS914EKLF clock generator, same as the X58A-UD7. Click to expand... Do not see that one in the freeware version. I see a 914EKL no EKLF
redduc900 Inactive Moderator Joined Dec 17, 2000 Location Portland, OR Aug 25, 2010 #4 Then I would contact the author and see if the ...EKLF PLL is supported in the newest shareware version.
OP Hardass Senior Member Joined Nov 3, 2001 Aug 25, 2010 Thread Starter #5 redduc900 said: Then I would contact the author and see if the ...EKLF PLL is supported in the newest shareware version. Click to expand... Yep, donation sent.
OP Hardass Senior Member Joined Nov 3, 2001 Aug 25, 2010 Thread Starter #6 He is asking for its Clock Generator which I can not see as mobo is coated with conformal. Help??
dejo Senior Moment Senior Member Joined Nov 11, 2001 Aug 25, 2010 #7 the clock generator should be the number he just gave you. never looked at mine so n ot sure
OP Hardass Senior Member Joined Nov 3, 2001 Aug 25, 2010 Thread Starter #8 I sent that to him, he responded enjoy OC but nothing about when it would be added.
OP Hardass Senior Member Joined Nov 3, 2001 Aug 25, 2010 Thread Starter #9 For the X58A-UD3R the setfsb setting is ICS9LPRS914EKL.
dejo Senior Moment Senior Member Joined Nov 11, 2001 Aug 25, 2010 #10 thanks Chuck, I may check this out next time I power up the ol lady
