I don't quite understand what the thick wall pipe equation is for
The only way to really determine the best thickness for a perticular setup is to just try a few thicknesses and see what works best. At least these models can tell you roughly where to start.
matttheniceguy said:The reason for a cold plate is to use a pelt on a cpu which is smaller than it. If you had a pelt that was same size as your core, that would be ideal, unfortunately pelts can't compete with processors as far as watts/area.
You don't want to just touch the cpu to part part of the pelt, because that part of the pelt wouldn't be able to take the power load. If the whole pelt is 200 watts, 1/10 the pelt will only be 20 watts. If your pelt is bigger than your processor (and I will be) you need a cold plate.
