- Jan 23, 2005
- Keystone Lightville, MA
crap godman got 200th post. the guys ram is running at pc3200 2-2-2-5 with 2.5v's. its showing zeros in cpu-z for ram manufacturer.
g0dM@n said:I'VE SAID THAT SAME EXACT THING IN ABOUT 10,000 DIFFERENT THREADS, and people still buy 2x1gb. I mean, some people also say "it's so that I don't have to upgrade later," but if they are to upgrade "later" then the ram prices would be less anyways.
pfffffffffffffff
well for the price then its a good deal for you imo.frenzy20 said:Sweet, I'll look at them tommorrow.
I won't return unless other people are getting much better results, these are for a rig that will be running stock, no ocing at all.
I told you that after you freeze it the sticky stuff will solidify, after a while it will heat up again from room temp and become sticky again. You'll have a couple minutes after the freezer to take the spreaders off, and then put back on...frenzy20 said:Even if they are UTT, they aren't very good.
The heatspreaders won't go back on though, will they?(if i freeze them)
I don't think they will bend enough to see the chips.
I can't return them, they do the settings they say they will (2.5v, 2-2-2-5, pc3200)
g0dM@n said:If we never took chances we'd never have good OCing parts... right? I went through 4 sets of TwinMOS (UTT) 2x512 until I found ones I liked. The funny thing is that I'm replacing my current TwinMOS UTT with OCZ VX GOLD PC4000.
