I used an E8400 on this Abit IP35 Pro and got to 9 x 450fsb no prob, stable and all on prime. Now on the Q6700 it seems I can't get passed 350fsb. If I push it to 375 it gets caught in the windows xp sp2 logo and keeps loading forever.
I got an OCZ 1000 watter, 2 gigs of G.Skill 1066mhz ram with 5-5-5-15 (I got manual timings no in BIOS). I'm using an Antec 900 and the celsius temps are pretty good. Cores idle at around 27, ambients around 29. I'm using a 9800GX2 for the video card. I got a Zalman CNPS 9700 on the CPU. Tons of fans in this case, and I also have a small 40mm on the Northbridge.
I've been using these parameters
Vcore = 1.4850v
VTT = 1.42v
MCH = 1.56v
GTL Ref = 65% on both 0&2 and 1&3
DDR2 Ram = 2.1v (as the voltage listed in the item specs in newegg)
I'm leaving the Southbridge at stock temps, I wouldn't think I need to raise these, would I?
I've been keeping the multi at 8 and trying to reach a 375fsb, but can only do 350fsb. I've tried combinations of this setup along with having the DRAM speed on default and on 1:1. I've also tried switching manual timings to auto and vice versa trying all combinations of dram timings and dram speed.
Any suggestions? I'd think 1.42v and the 65% gtl ref would be enough to stabilize Vdroop. I dunno. I'm kinda confused how some ppl, when overclocking, lower the gtl ref while others raise it. I've had more luck lowering it, when I was overclocking the E8400 on this board. I read that lowering the gtl ref tricks the motherboard into giving the cpu more power to compensate for Vdroop.
Anyhow, you guys reaching 375fsb+ on this cpu+mobo setup? Any suggestions?
Vcore = 1.4850v
VTT = 1.42v
MCH = 1.56v
