well I can't say that If I were to do it all over again i still would have bought this stuff, but since im so close im not willing to give up.
okay, so I remounted the cpu block again, and fixed up the as5 (did a primo job of applying it!) and blew out the socket holes with some spray, let the spary evaperate (sometime it squirts warer, so Im just being safe) and then I hooked it back up.
I remounted the nb passive sink, I mixed some as5 with the AS adheasive, I think that it was not cooling well in the middle, it should do great now, I did a test to see if it was still adhesive and it was, acutally, maybe better. SO that should be good.
I remounted the dd maze 4 on my 5700, cleaned up the as5 (it wasn't bad) and tightend the screws in 1/8th turn segments like the DD video says.
still no video
So I pull unintall the block and examine the core, It has a chip in it, a very small one in the corner, and it may have a crack in the other corner, This might be since when I initially insalled the blck I cranked it all the way down and crushed the core. It might be because I bashed something into it when I was uninstalling that dang vga sink from zalaman. Either way the card is gone. All $127 of it.
So I tried to install the block on the old card, a TNT2 32mb I can see after I pop the sink, and the holes arn't lined up right. So I put some as5 on there, since I wiped off the white stuff and installed the original sink. It would have been fun to overclock something like that.
So I boot and I was still getting crappy temps. Then I turned my case upright and all the sudden the computer restarts! what the heck! So I power off to check everything. Then I power on all seems fine, three secounds pass, the mobo sounds the post beep, the monitor just comes out of sleep mode and then the comp shuts off.
So I hit the power button to turn it back on. Nothing, I pull the plug and the red mobo sleep light goes off, then plug it back in and hit pwoer button, It comes on, but only for three secounds. I can't seem to find the problem. I tell you, its days like this that make me sure in all my mind that I don't want to be an IT guy.
help would be apreciated now more than ever. Im pulling an all nighter tonight, so suggestions are much appreciated. Much!
