FSB Bus Frequency – 255GENIE BIOS Setting
LDT/FSB Frequency Ratio - x 3.0
LDT Bus Transfer Width - 16/16
CPU/FSB Frequency Ratio - x 10.0
PCI eXpress Frequency - 100mhz
K8 Cool’n’Quiet Support - disable
Cool’n’Quiet MAX FID - auto
CPU VID Startup Value - 1.450v
CPU VID Control - 1.225v
CPU VID Special Control - above VID * 136%
LDT Voltage Control - 1.40v
Chip Set Voltage Control - 1.80v
DRAM Voltage Control - 2.80v
DRAM+ .03V If it’s not 3.2V - Disable
DRAM Frequency Set (MHZ) - 200 (dram/fsb : 1/01)GENIE BIOS Setting >DRAM Configuration
Command per clock (CPC) - enable
Cas latency (tCL) - 2.5
RAS to CAS delay (tRCD) - 04 Bus Clocks
Min RAS active time (tRAS) - 07 Bus Clocks
Row precharge time (tRP) - 03 Bus Clocks
Row cycle time (tRC) - 07 Bus Clocks
Row refresh cycle time (tRFC) - 16 Bus Clocks
Row to Row delay (tRRD) - 03 Bus Clocks
Write recovery time (tWR) - 03 Bus Clocks
Write to read delay (tWTR) - 02 Bus Clocks
Read to write delay (tRWT) - 03 Bus Clocks
Refresh period (tREF) - 3120 Cycles
Write CAS latency (tWCL) - Auto
DRAM Bank Interleave - Enabled
DQS Skew Control - Increase Screw
DQS Skew Value - 0
DRAM Drive Strength - Level 7
DRAM Data Drive Strength - Level 2
Max Async Latency - 07.0 Nano Seconds
Dram Response - Fastast
Read Preamble Time - Auto
Idle Cycle Limit - 256 Cycles
Dynamic Counter - disable
R/W Queue Bypass - 16 x
Bypass Max - 07 x
32 Byte Granularity - Disable (4 Bursts)
-DFI LANPARTY UT nF4 Ultra-D Socket 939 NVIDIA nForce4 Ultra ATX AMD Motherboard - RetailHARDWARE
-MSI NX6600GT-TD128E Geforce 6600GT 128MB GDDR3 PCI Express x16 Video Card
-AMD Athlon 64 3200+ Winchester 1GHz FSB Socket 939 Processor Model ADA3200DIK4BI
-OCZ Peroformance 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 433 (PC 3500) Unbuffered Dual Channel Kit System Memory Copper Heatspreader Model OCZ4331024PFDC-K
-ZALMAN CNPS7000B-CU 92mm 2 Ball Cooling Fan/Heatsink
-Antec NeoPower ATX 480W Power Supply 100 - 240V TUV, UL, CUL, CE, CB, FCC
-Thermaltake Kandalf VA9000BWS Black Aluminum/Steel ATX Full Tower Computer Case
-1 80gb MAIN hdd SATA
-1 250gb sata hdd, 320gb IDE external, 1 200gb IDE
with these right now, how much can i push it? what can i change to become mroe stable? thanks... i'm only able to prime for about 9 mins without errors... but couple hrs before with the same settings i primed for about 4 hrs stable without problems... but now only 9 mins... any reason?
edited
lower fsb to 250x10 and sam ram settings. priming right now... so far stable... hope it stays that way
