- Jan 10, 2012
set it to ultra high and prime it.
Now you are confusing me, so you are telling me that 49c while playing is a lot?? I understand that under prime testing temps is not supposed to get pass 55c which is not happened???
I've seen these chips go unstable after 52c. Your on the warm side.... In game Cpu usage has spikes unlike P95 just being a constant calculation and load.
If you looking for a stable NB, lower the Cpu to definite stable clock, perhaps 3.8ghz and try to stay under 50c and not a stitch more. Run the NB up, you can use the bus frequency for fine tuning...... Try and clock the HT at the same speed 2.4/2.4ghz. I always liked mine matching, and usually small 200mhz ocs don't require much voltage if none at all. So 2.2ghz is plenty for daily stable, you only see the difference in benchmarking any ways.
Ok ht and cpu nb is set to 2200, prime is running, here is picture.
How long you want me to run test?
Well as much as I was able to read on the net for this cpu is that it can go up to 4 ghz with no problem and with cpu nb 2400-2600. This computer I mainly use for gaming so basically my goal is to reach 4 ghz with cpu nb freq as much as I can get because thats whats matter for gaming.
take the cpu/nb up 200 mgz and the ht up 200 mgz, lower the cpu vcore two clicks.
reprime it and post the same screenshot.
yes this is droll but we'll get it up to speed.
Ah BUT, this 2400/2600mhz was done at my house on liquid cooling, often times even passing 3ghz -3.2ghz NB for benchmarking.
I can tell you from your sig, that Hyper 212 has nothing on my water block.
It's just a little warm. that's probably all it is IMO.
Hopefully you have active cooling on the NB before OCing it??? no??? Ahh, maybe that and some VRM cooling might help?
Can never have enough cooling for overclocking my friend. No matter how long you want to test for....
please do. did you adjust the cpu/nb and ht?
Nice goal, but it's not a gimme as you think. There are plenty of 965's out there that hit the wall at 3.8
Looking at how yours is progressing, I'm thinking it's one of them.
