- Jan 29, 2011
- Purdue University - Indiana
- Thread Starter
- #41
Oops, the D12SH-12 is a high speed Yate-Loon fan.
Thanks, m0r7if3r, for the links.
What's the deal with Tygon tubing? I hear it's good for areas with potential kinks (maybe some parts of my case, but probably not), but it's quite expensive compared to some others. Is there a good all-around brand of tubing that has multiple color options?
as good or better than Tygon for evaporation rate, comes in different colors/uv treatments, and is more flexible.
Evaporation rate, wut? It's supposed to do tighter turns and is softer.
It doesn't let as much water evaporate through it as some of the cheap tubing does (like thermaltake crap), and yeah it makes better turns hence why I am going with some 1/2 UV blue when I get a new case.
Most plastic type general tubing that you pick up from a hardware store is more porous than something like Tygon (which is still a little porous) and water will evaporate at a very slow rate through it. Hence why people have to fill there res every once in a while after a few months if they use lower quality tubing. I thought this was well-known knowledge? Maybe since so many people use quality tubing they don't really notice.if water is evaporating from your tubing something completely different is wrong because your tubing is leaking.
I came across the Primochill tubing while I was looking and liked the colors, so I may just go with that if the Tygon isn't really necessary. I just wish the Tygon came in more colors.
