This is for the GTX 260 216 and likely others in the family is what card I am specifically talking about about. Lets stick to the context.Not all the time however, I showed 4 phase change/LN2 setups what air power could do by overclocking a 8600GT 100% on air in a OC competition(vmod for vGPU and vMem was required), but yes, heat is often the limiting factor. Too bad I can't just use my Accelero SP1 on this card, would've been awesome
btw, the bios flash, does it really work?
edit: what does a stock card show for voltage in nibitor?
mine shows this:
Extra: 1.12
3D: 1.05
2D: 1.05
So I think my card already has the mod done by default right?
Actually if you push it too hard and if there's artifact, you get a lower score instead of a higher one
It didn't artifact, it didn't even artifact at 771 core, however it did crash at the end of the last gpu test
Still, I find 756 a very respectable OC
but as i have stated, temp might get higher after 20 mins of stress,
it will reach 80C and at those speeds it will artifact.
the gpu is asking for it, COOL IT! =)
pls, don't just say xfx
write down what model you have, all the frequencies , the temps and your computer specs
this will help me and others try to give you an answer.
and Drinkyyoughurt, the addition fan doesn't cost more than 10$
Oh you meant that?
That won't have an effect on my card, the stock cooling solution is different on my Sparkle + I already have my casefan pointed at my card
the casefan won't do.
i am basing my answers on the temp you told us.
after 2 of those tests even with only 1 card running, my temp was 58C
your temp was 13C higher, this means your card idles also 13C higher, which leads me to suppose there is some stagnant air where your gpu fan lies.
the best solution would be 2 fans, 1 blowing at the gpu fan and another in the front taking the heat away
as last question, have you tried playing for more than 20 mins and see if it artifacts and what temps it reaches?
The reason for my GPU becoming so hot is because I have my fan set at 55% and not 60, with the fan at 100% it barely breaks 55c. The card also idles at around 43c which isn't that hot at all.
then go higher!!! until you notice a drop in performance in vantage or artifacts
