what im after is something that will give me good cpu cooling but without the noise of a delta, so ive decided to fit a 80mm or 92mm fan to a heatsink
now im not sure which heatsink i should use, i was thinking either the thermoengine black heatsink or the fop38 one.
and as for fans itll most probably be the:
Sunon case fan 8cm: 39CFM, 32dBA or the
PANAFLO 92mm HIGH OUTPUT: 56.8 CFM, 35 dBA
before i place my order id like to know what other good heatsinks are out there, and how much difference the 92mm fan would make over of the 80mm one.
