i was getting that same problem today. i had to shut the seti down, and restart. i would control alt delete to see if i was at 100% load to know its working right.AZN said:yes its weird, folding only is 50% load. do u think a reinstall of OS will make it 100%? if so y?
AZN said:score for what?
my best so far is like 108xx mips and 57xx sandra memory. i cant get my memory to OC so im stuck just under ddr400j2me_tech said:
cpu, memory benchies.
prime does not know how to use both cpu's.AZN said:its still at 50% so is prime. heck i even ran prime witht another cpu program just to get 100%
jdmcnudgent said:prime does not know how to use both cpu's.
howw do u run 2 prime or folding?j2me_tech said:
agree, b'coz prime95 is not utilise for HT. tat's y we need to run 2 prime95 to make it use 100% of cpu usage.
azn, reinstall windows will give u better score, i hit 11*** cpu arithmetic with 295fsb.
NookieN said:Meh, maybe. On a dual channel system two Primes might be able to do slightly more work than one. With my single channel system I don't see any temperature difference with two instances.
As I said earlier, you're probably better off running two different things (such as Prime and Sandra, or Prime and folding, etc).
I'm tellin' you guys, running two instances of Prime isn't going to do much of anything. Prime already uses every part of the chip that it can as a single thread. [/B]
For an SMP system, yes running two Primes makes sense. The problem with running two copies of Prime on an HT system is that a single thread already uses all of the execution units it can. Hyperthreading works by letting another thread use an otherwise idle part of the chip. Prime, however, uses only a few datapaths in the chip (mostly SIMD floating point, plus memory operations).
There's a short thread that has more on this topic here: http://www.mersenneforum.org/viewtopic.php?t=453
TheGr8s1 said:this is certainly an interesting topic. i will run prime95 twice as some of u have suggested earlier. see what will happen next.
