This really sucks !! I just broke a tab off of my Asus A7V133 !! So now what ?? I guess I'll have to make a something that grabs all three tabs.....I mean the two tabs that are still there !! Or buy a whole new block, one that uses the four holes around the socket.....which sucks....cause I just got this new block. So any suggestions would be greatly appreciated !!!
Im thinking of making an Aluminum plate that uses the four holes...but Im not sure about clamping-down a waterblock with that setup.....Im afraid of tightening too much on one corner of it cracking the die on the top of the CPU ....which would be VERY BAD !! ....as you all know. But using the four holes seems to be the better way to go.....anything is better than breaking off the tabs of a socket !!
The funny thing is, I have a mechanical engineering background.....and I've worked with lotsa stuff much tougher to do than attaching this waterblock. This just goes to show how badly this socket design licks a swollen, infected mule d*ck !!
Thanks in advance !!
