- Sep 17, 2002
I buy computer speakers cos I'm 16 and I pay for all my own comp/entertainment parts, so Creative 5.1 system for $70 is a damn good deal.
Taylor said:I got creative 5.1 for $99, and I'm very happy. However ........
slipknot said:Aopen made the board with the tubes. I know there are a couple reviews around the web on it....give me 5 mins to give you some links
Avatar28 said:
As far as overdoing it goes, yeah, I'd say just a bit. But, hey, whatever rocks your world, you know? As long as you're not robbing someone to get the parts, go for it.
Henry Rollins II said:
Oh did I forget to mention that I have 2 sets of "satellites"? The scan-speak is for movies and the computer alone. I have a 3-way floor stander built solely out of PA components. Measured specs: efficency 98 db/1w/1m, max measured output 127 dB(150 dB peak)@1000 watt input. Amplifier borrowed Crown MacroTech 5002vz: 2 x 1775 watts@20-20kHz 0,1% thd kickass monster poweramp cost like 5000 dollars or something. I blew the crossovers but man it was loud
slipknot said:I'm a little late to the party, but I have couple things to say/respond too :
1) "Good speakers cost more then 1200+" ----This is far from the truth. Here are some KICKA$$ highly rated speaker manufactures.
Energy (the connoisseur line is the sweet spot)
PSB
Axiom Audio
Paradigm (Studio line is very nice)
Phase Technology
This list could be MUCH larger, but it gives you an idea. I know all of those guys produce very expensive speakers, but they also produce great mid-range speakers.
2) I don't know about you guys, but I would take a nice highend pair of headphones over computer speakers anyday. I came to this conclusion when I was playing a game called system shock2 a couple years ago. I swear I almost wet my self playing that game late at night in a dark room. Headphones really get me into a game. *Most* computer speakers can't do this for me.
3) "speakers are by far the most important part of your audio system" -- I beg to differ...ALOT..... Speakers are but one part of the equation. If you take a nice high-end set of speakers and match them up with something cheap $150 technics reciever, you will get $150 sound. PERIOD. I've heard testing done like this and entire instruments will dissapear. The sound will become very FATIQUED. There is no pounding in the low end and no pizzazz in the highend of the spectrum. It just doesn't work. You MUST match your system up correctly. Even the wrong cabling can cause this to happen.
4) Here goes my current dream PC sound setup. Does it take up alot of room. YES. Would it cost alot. YES. Would it destroy any dedicated PC speaker setup. ABSOLUTLY
YAMAHA CAVIT RP-U200 RECIEVER
ENERGY ENCORE SYSTEM
*note* I would probably never buy this because I'm completely happy with my headphones
Azzkiller said:
Why would a guy have a pair of martin logan electrostats powered by a 200 dollar JVC reciever, if your theory of amplification was right? Do you really think that guy is dumb enough to buy a cheap reciever if it made a difference in sound quality? The speakers are the weakest link, period. It is easy for an amplifier to increase a signal, or a DAC to convert a digital signal to analog. But it is not easy for a loudspeaker to convert electrical energy to mechanical sound energy. Just look at a loudspeaker's efficiency, most are less than .5% efficient!!!
If you think you can hear the difference between amplifiers, please contact Richard Clark at www.carsound.com or Tom Nousaine, they both do tests all the time to prove their are no audible differences between amplifiers. Before you slam me for saying that their are, remember we are talking about audible differences in an amplifiers linear range. Check it out:
http://www.talkaudio.co.uk/vbb/showthread.php?s=&threadid=18815
I reallize this must come as a shock to you guys, but quite frankly it makes perfect sense if you read over the rules.
One of the reasons you might think their is a difference, is because the levels are not matched properly. If one amplifier is 1dB louder than another, it will sound different, and can be distinguished by many people. The problem is, that tests are not conducted scientifically, and when you take Richard Clark's test, you will find he has thousands and thousands of dollars worth of calibration equipment to match the amplifiers.
Don't fret though, I am in no way saying you should drop your expensive amplifiers and run. There are MANY MANY reasons why you should buy a quality amplifier, such as build quality, power output, ability to drive low impedence loads, and duribility and looks. I am saying however, if you think buying an expensive amplifier will allow magnificent sound quality, you are really buying for the wrong reasons. If amplifiers made such a sound quality difference, I doubt the guy with Martin Logan electrostats running off a JVC reciever would be happening.
Remember this though, if you REALLY can hear the difference between amplifiers, Richard Clark has 10 thousand dollars for you.
As for the cabling, yes I agree, you need good cables, make sure you get thick enough wire so that their is not an appriciaable voltage drop between the amplifier and the speaker, home depot has some 14awg for 25 cents a foot I believe. And for the low level interconnects, if you get noise in your system, the 2 dollar variaty might not do.
Oh and that Aopen motherboard should win gimmick of the year. Those tubes on the motherboard cant be good for keeping the heat of the case down.
P.S. I use a techincs 250 dollar reciever!
P.P.S. I hope a flame war does not start.
So if I tell him I can hear a difference he will give me 10.000 bucks? I beleive that.......NOT
