- Jun 9, 2009
Good Evening All,
I am currently stationed overseas in the US Navy on deployment. Will be returning to the states here in about 2 months or so. Plan on picking back up online gaming (Call of Duty, WoW, Farcry 2) again and would like a solid machine to do so on. I feel my understanding of components is decent and have a good grasp on it all. If you could please review these parts i would greatly appreciate it.
Monitor:
SAMSUNG TOC T240 Rose Black 24'' 5ms HDMI Widescreen LCD Monitor
Case:
Antec Nine Hundred Two Black Steel ATX Mid Tower Computer Case
Mobo:
GIGABYTE GA-EX58-UD4P LGA 1366 Intel X58 ATX Intel Motherboard
CPU:
Intel Core i7 920 Nehalem 2.66GHz LGA 1366 130W Quad-Core Processor
GPU:
EVGA 01G-P3-1182-AR GeForce GTX 285 FTW Edition 1GB 512-bit DDR3 PCI Express 2.0 x16 SLI Supported Video Card
RAM:
OCZ Platinum 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop
PSU:
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power
Heat Sink + Cooling:
OCZ OCZTFRZTC Freeze Extreme Thermal Conductivity Compound
XIGMATEK Dark Knight-S1283V 120mm Long Life Bearing CPU Cooler
OS Hard Drive:
OCZ Vertex Series OCZSSD2-1VTX60G 2.5" 60GB SATA II MLC Internal Solid state disk (SSD)
HDD:
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive
Disc Drives: x2
HP 22X DVD±R DVD Burner with LightScribe Black IDE Model HP 1140i
OS:
Microsoft Windows Vista Home Premium SP1 64-bit for System Builders
Price: $2,071.87
Here are my basic questions:
1. Since i do plan on OCing the 920 to about 3.5GHz will this PSU, Heatsink and Cooling Compound be enough to support it to that clock speed?
2. The tech specifics say my current Mobo only supports "DDR3 2100+/1333" and if i have chosen 1600MHz DDR 3 Ram, i was told it runs at stock speed of 1033MHz and i will have to OC it to get the most out of it. Is this Mobo/RAM combo good meshing?
3. For the games i plan on using it for (MMO's & FPS's) will the GTX 285 and this CPU/RAM be enough to play a majority of them at highest settings once i get my clock speed up high enough?
4. Will my case support ample enough cooling?
5. Any tips on first time building/ocing experience. For example any helpful sites to help walkthrough the virgin experience.
Thanks for any help people provide, i am extremely grateful.
Monitor:
Case:
Mobo:
CPU:
GPU:
RAM:
PSU:
OS Hard Drive:
HDD:
Disc Drives: x2
OS:
Price: $2,071.87
