Unfortunately the companies that make bad PSUs know they are bad and don't send them out for review.
Somebody has compiled a list of reviews of bad PSUs:
http://www.johnnylucky.org/power-supplies/psu-lemon-list.html
"exploded during testing" means bad.
Buy whats been tested, lots of choices.
^ This
I don't think these forums are using Wikipedia source notation rules, so the expertise and status of the posters on this website can probably work as substitute for sourcing reviews for each bad PSU.
Plus, who cares? If you're in the market get one off the list of known good ones or suggested brands, and spend the money instead of trying to cheap out and get some Chinese brand. Alternativly, posts can always be started to get fantastic help within hours.
Assumed to be bad? Assumptions are bad. That leaves too much subjectivity to be accurate, and leaves the list questionable at best, or subject to whim and bias at worst.
All I'm suggesting is that a 'bad list' should be wholly substantiated with verifiable documented results, just as the 'good list' has been with direct links.
I'm going to get one to test...one of those Nidec psu's.
Should prove fun, and perhaps dangerous.
The guy sells some Delta blowers and Nidec tri blade 150cfm fans for 3 bucks each, worth a combo buy perhaps
