Ok, I have tried to get in contact with eVGA, although they are busy. I will have to wait until Monday.
I tried using the S-Video outlet on the 6800 GT, and it works. The only way I got the S-Video to work is to turn on the computer, then press the reboot switch on my case. So it displayed on the S-video, then I switched the mode to DVI on my monitor, and it displayed under DVI! But, something is very weird though. When I shut down the computer then power on again, the monitor goes idle. It won't display anything, I shake the mouse stomp on the keyboard and it just stays idle. Then I hit the "reboot" button, the computer reboots and it displays under DVI. It only will display when I hit the "reboot" switch on my case, not when I shut down then power on. I am very confused and have no idea what is going on. So, let me repeat this more clearly.
If I:
1. Turn on the monitor
2. Immediantly turn on the computer
Outcome: Starts off active (green led) then after a couple seconds, monitor goes idle (orange). Screen stayed black the whole time. Although with my previous 6800 GT it would display fine, I could turn on the computer/monitor in any possible combination and it would display
3. I shake the mouse rapidly and tap the spacebar a couple times.
Outcome: Still Stays Idle.
4. I press the small "reboot" button on my I/O panel.
Outcome: The computer reboots and the monitor turns active (green), and displays bios welcome screen.
5. The monitor is displaying, so I decide to shut down then turn back on INSTEAD of pressing the reboot button.
6. While the computer is still on, and the monitor is displaying from when I hit the reboot button, I turn off the monitor. I then turn the monitor back on.
Outcome: It still displays. Nothing wrong.
7. Turn on the computer first, then turn on the monitor.
Outcome:Starts off active (green led) then after a couple seconds, monitor goes idle (orange). Screen stayed black the whole time.
I also randomly recieve this error from my monitor:
"DVI-D
Cannot display under this mode" error flat out in the center of the monitor. No matter what I do it keeps on giving me that error. I have to have the monitor and computer shut off for about a minute, then turn on the computer and monitor, press the reboot switch, then it will display.
I assume maybe it is just giving me this because I don't have any HD plugged in? Anybody clue me in? I really don't think the monitor is the issue because it worked perfectly with my other card.
On a good note, my raptor shipped out today. I'll recieve it in three days, although it is no good without my graphics card. I am going to plug it in, install windows, then try to reboot and see if it makes a difference.
