Whosyodaddy: He also wants to buy a heat generator, and test the cpu waterblock
What kind of engineer is your dad?whozyodaddy said:I just had a talk with him, he did all these stupid calculations and tells me that idle my cpu idle temps SHOULD BE 50 some celcius and under LOAD it should be 70c. I tell him so many other people have my setup, and their parts are alot cooler even overclocked. He tells me the only way that is possible is if their room is a refrigerator. He is telling me the $5 heatsink is better than my $450 watercooling setup. He guessed that my room temp/water temp is 30c just by touching with his finger, so the absolute best temperature I will recieve idle would be 50.
Excuse me while I shoot myself.
Whosyodaddy: He is telling me the $5 heatsink is better than my $450 watercooling setup.
Hey! I'm an engineer and I waste time and money on stupid cooling things all the timeCJ-5 said:...he is an engineer and they are trained to think about cost vs. effectiveness. In other words if a $5 item will do just as good or nearly as good a job as a $450 item then in his mind it's not worth the extra cost for increased performance and you should use the $5 item.
ribuck97 said:1) Since the radiator is sitting on the bottom of the case:
a) Do you have a hole cut in the bottom of the case for the fans to push/pull air? Not having a hole will detriment the performance of the radiator.
b) Having the fans blow into the case would provide the best benefit (imho) because they would blow directly onto your video card.
2) It looks like your video card mount is incorrect... Why are you not using all 4 holes on the mounting block? It also looks like you have no screws (threads) above the gold washers on the mount. Did you cut these? If you don't have any, I would suspect you do not have the block screwed down tight enough.
3) Did you remember to plug the 4pin power adapter in to the video card?
4) I assume that is you "holding" the 6002 block up to your cpu... When you do that, is there any pressure put on the corner of the video card due to all of the cabling you have there and then the 3/4" tube stress from the pump-> cpu feed?
5) Lets go over your loop... from the picture it looks as follows:
D5->6002->Maze4->BIX2->Reservior->D5
This correct?
6) Lets discuss the CPU mounting... When you mounted it, did you mount it with the step side over the socket lever? Since this block is mounted with the discharge on the bottom, have to let it run while its on top for about 8-10 hours to bleed air out of the cpu block? Do you have the center barb (inlet) coming from the d5? If you don't, then your tubing is incorrect. Does your assembly match here: http://www.swiftnets.com/products/installationguide_MCW6000_2-775.pdf
4) For a stacker, it seems as though you have little room inside.
ribuck97: It also looks like your reservoir is only 2/3rds full? I don't use a reservoir, maybe someone else can comment but I thought it should be filled with little to no air...
ribuck97: since the cpu block is the highest part of your loop, all of the air bubbles when you bleed the system will collect in the top portion of your block
Whosyodaddy: I can only use three... the fourth screw conflicts with the mobo heatsink.
whozyodaddy said:My dad is an engineer and says that the water just doesn't work, it's fake. He doesn't believe it works... I told him that it does work for other people, he replied saying that they could just be friends of the company. Any way to prove to him it does work? He blabbered on about the DeltaT equation yadada 'q=hA(Tf-Tcm)' . He wants to know how much watts it can transfer, he wants technical data... people using transistors, etc. He thinks the problem is the heat is just not transferring to the block. How can I show him that my parts DO work and are not scams?
