- Mar 3, 2005
- Houston
whozyodaddy said:@iceage: No, AS5 didn't go anywhere else. I am not using a custom mount. Just the LGA 775 mount that came with the 6002.
@Scroatdog: I leak tested outside the case, then drained and put inside the case. Although I did change the order of my loop when I moved it inside the case. Nothing leaked onto any components.
@Jas: Yep, my pump is working.
@Phaeton: You have to understand, with water my system only stays on 30 seconds max. All the components get too hot. I didn't measure the temp of my water, but I'm pretty sure it is room temp. Rad fins are not warm, just normal to the touch. Maybe even cool. I touch the cpu and gpu block and it is cold.
RESULTS ARE IN. I INSTALLED THE AIR COOLING FOR BOTH GPU AND CPU.
When I booted up I still got the same artifacting all over. a's appeared all over the screen when booted and going into bios. Bios showed the cpu at 48 with the air, water showed 70. I actually was able to get into windows this time. Still gave gibberish text and ****. When Windows loaded, the resolution was at the lowest - 800x600 I believe. I when to my appearence and it didn't even read my 6800GT! For display it said default or something whereas before it showed my full gpu model. I couldn't even go into 1680x1050. Weird - it didn't read my graphics card even though my monitor is plugged into it, instead it was using onboard. I think my graphics card is the problem here, but I don't understand how it got f'ed up. Do I have to buy another graphics card???
I had this problem when I got water on my 6800 gt. I was getting serious artifacts. I just cleaned everything with rubbing alcohal and let it dry over night reinstalled it and it fired right up. The graphics card is likely to blame as other have said. You probably have not fried anything, suprisingly, computers arent as fragile as people think.
