- Nov 16, 2010
- Orlando, FL
Im lookin to build a budget gaming desktop
So the first part im lookin at on newegg is a duel core cpu
im trying to decide on 2 different cpu's
the first one is AMD Athlon II X2 260 Regor 3.2GHz 2 x 1MB L2 Cache Socket AM3 65W Dual-Core Desktop Processor ADX260OCGMBOX
$67.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103873
2nd is AMD Phenom II X2 560 Black Edition Callisto 3.3GHz 2 x 512KB L2 Cache 6MB L3 Cache Socket AM3 80W Dual-Core Desktop Processor HDZ560WFGMBOX
$99.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103887
Im leaning towards the $67.99 since im going for a budget build but if the other one or any other cpu someone can suggest under $100 is much better then ill go for that one
The main difference im looking at between the 2 is the cheaper cpu doesnt have L3 cache but has better L2 which is @ 2 x 1MB when the more expensive one has only 2 x 512KB L2 but has 6MB of shared L3
So heres my main question, Is L3 cache so important for gaming that i should spend the extra $32 to get the cpu with L3 cache even tho it has less L2 cache?
Im thinking the extra $32 would be better spent towards a better Graphics card
Thank You in advance for your guy's help/advice
$67.99
$99.99
