I'm hoping you meant
corps.
Long time Linux user here. It's come a long way since you last tried it. I can't disagree with previous recommendations in the least. I would add, however, that if you're interested in gaming, you should pick out a distro that easily supports Steam. I'm pretty sure that is available via snap package so that's what I'd look for. A Snap package gets away from the "I need the distro with the latest libraries etc." because it packages the dependencies in the snap. That makes it a little heavier than just installing the app but makes keeping up with the latest and greatest a lot easier.
You can partition your system drive or add a second drive on which to install Linux for a test drive. 25GB should be plenty for the OS and some games. (I haven't looked at games so I might be wrong.) I can install a server in 5GB and a full desktop in 15.
Good luck!
