- Thread Starter
- #21
My next purchase was a few odds & ends from Bitspower & Monsoon. Here are a few more pics.
The new Bitspower 120mm Water Tank Mount Panel (BP-120WTMP-BK) is a much better direct fit with no mod required whatsoever. I highly recommend this part for the Swiftech Heatsink kit over my previous selection. I may have to add spacers to keep the screws out of the fan but I will cross that bridge upon installation into the case. You can immediately tell that this will allow better airflow from the fan below it than the previous mount.
Next is the installation of the Bitspower G1/4" D-Plug Male/Male Coupler Set (BP-MBWP-C07) which is a better choice over the included coupler to connect the reservoir to the pump since it allows the lower collar to be part of the system. It really tidies things up in that department as shown below.
All installed with Monsoon .999 Fine Silver Bullet Antimicrobial G1/4" Plug (MON-PLUG-AG-BLK), Premium G1/4" Stop Fitting (MON-SPL-WH), Light Port 90d & 45d Rotary Angle Adapter - 3/4" OD (MON-LP-45-34-WH) & (MON-LP-90-34-WH), Free Center Compression Fitting - 1/2"ID x 3/4" OD - Modders 6 Pack (FCC-1234-6P-WH).
A different angle. I chose the matte white since I like anything with a matte finish. My matte choices where black or white so I chose white for contrast. Also, I am using black o-rings for easier inspection.
There were a few D-plug sets from Bitspower to choose from. I needed to find something to make the 15mm reach (excluding 5mm G1/4" threading on each side) since the supplied 10mm wasn't cutting it. The C44 & C38 seemed too deep for my liking,the C28 seemed a perfect fit but I didn't want to chance it coming in a tad too short and not sealing well enough, and the C07 seemed just right with a extra 5mm buffer.
Anyway, you get the idea.
The saga continues ...
