Something else you need to think about regarding thermally throttling the fan is CPU core dependant vs water.
I haven't tried either myself, but "Think" it would be a much nicer and smoother ramp up/down using water.
...using water temperature...because of water's natural specific heat storage benefits, you would essentially give your ramp up/down a natural capacitor of sorts and smooth out that ramping problem.
You would simply have to set the water temperature to a correlating acceptable core temperature.
For this reason, I think ultimately you'll need to look beyond motherboard control if you are very particular about noise.
I only say this because my work computer has a PWM fan on it, and I personally find that ramp/up down every time I do something intensive to be a bit annoying. Rather than just spin up partially, it' pretty much pegs high rpm then back down to low in very short order. Perhaps this could be smoothed out with more precision PWM settings (Work computer locked down by our big brother IT folks), but I just haven't been happy myself at least with that rig. It's definitely better than listening to a fan full bore all the time, but the ramping up and down so quickly is a bit disappointing.
The solution to this will of coarse require a fan controller, one that has the ability to control fans via some sort of temperature probe you can attach or insert into the fluid stream somehow.
This is an interesting suggestion, thanks.
Could the water become an unreliable source, if in time too much of it evaporates?
As pointed-out further down in the thread...
This jagged ramping up/down may simply be due to poor PWM config, or a fan with a top RPM that's a bit too high for the 10% increments.
But it still sounds like an interesting 'supplement' to the usual core measurement that's done, so thanks!
As far as you're discussion on PWM vs voltage control of the fans...either is fine. The only real advantage I see with 4 pin PWM fans is "Some" have a little lower RPM floor, but both if designed optimally are equal on the noise front. If anything, my preference sways toward voltage regulation, it's less testy and has shown to have smoother sound quality in some fans.
Isn't PWM also much more efficient?
Interesting point RE 'smoother' sound quality for linear voltage control, quite surprising.
I haven't decided quite what I'm going to try. I have my son's pc that's fairly minimal, it just has a single MCR320 mounted in the top with one case fan. In his rig, I may go ahead and try a set of four Arctic Cooling F12s and give PWM a try, I just don't think it's quite the control I want. I've got a single loop though, so it would probably work ok with some careful PWM settings. I just think controlling by water temp would be much more ideal for water cooling.
I love how you say a single MCR320 is fairly minimal, in reality it's not compared to the avg. Joe's PC!
Now if someone could figure out a way of taking the PWM signal from the MoBo headers and smoothing it to a nice curve; then we could probably build a fully internal controller that takes the MoBo's PWM signal, makes it nice and smooth and then feeds that signal to the fan.
That would be so sweet,
A device that could take the signal from both headers, pass it to 2 PWM circuits of a controller, but in a more 'smoothed-out' fashion
Yeah, the more I think about it...the more I'm personally drawn to something like the mcubed Tbalancer bigNG/mini or AC poweradjust controller. Not quite sure which is better, but they both seem to have tools to tweak things via software.
Yeah, alas they're best options I've seen so far
The problem with running this off a motherboard is <SNIP> b) motherboard manufactuerers set up the PWM signal in 10% increments from 0-100%.
<SNIP>
B) is not so simple. While yes you can effectively jump in 10% increments, this works for lower spead fans because you incremently just 10% of the rated fan speed. 1000RPM fan jump 100 RPMS at a time, 2500 RPMS jump 250 RPMs. But a 6000 RPM fan jumps ~600+/- RPMs which is akin to switching a Hairdryer with 5 different speed settings up and down till it drives you insane.
This is one of the most critical points made so far...
It may mean having these 5400RPM's coming-off my MB's PWM controller is impractical
If your looking for a quiet system, then just go with a slower fan.
I may have to consider that if this 10% increment you speak-of holds true for my MB.
Especially if my MB is not able to lower these fans to 20% of their top-speed (1080RPM).
I guess I should 'bite-the-bullet', order, & find-out how bearable/annoying these 10% increments are on a 5400 PWM Nidec.
Maybe my MB's special... doubtful!
If your looking for maximum cooling, then you will need a high speed fan. IF you do this, you need to make a PWM Controller. There are no official manufacturers (at least that I could find 6-8 Months ago) and if they are, they are surely more than $100.
Assuming the 10% increments apply to me (they prolly do), & assuming they're
just bearable (the fans will usually be at their lowest RPM).
Do you still think it's
imperative to build or buy a discrete controller?
I don't mind paying more than $100 if a controller with 2x decent PWM channels exists, but it has to meet all my other basic requirements
Also I don't think anyone's explained (apologies if they have) what the problem is with pre-builts out there, that have several LVC & one PWM circuit.
b) If you try to just undervolt a high speed PWM fan, you will be plauged with Clicking and whining and you will regret it, not to mention you will loose performance.
Thanks for pointing this out, this conflicts with what one of the other posters was saying earlier in the thread.
c) The Motherboard option should only be used if you are going with a fan under 2000 RPMs. Even when I used a 2500 RPM fan, it was annoying.
Hmm, you're probably right, still tempted to try one though
Especially given I still don't know the specifics of the PWM control implemented for my MB, will find out ASAP!
Now, to the topic at hand. While I don't think a dedicated controller is imperative, as complicated as this is getting, I think it's probably a good idea. It will a) keep your wiring cleaner, b) allow you to see the RPM and fine-tune fans as you want and c) save you a lot of headache separating the fan's controller & voltage wires, running them all over the place to your headers (see a)).
There's not too many controllers that bring anything equivalent to a MB+BIOS/SW wrt (b) (at least for my needs).
But I'm sure once everything's set-up & there's wires everywhere, that it'd be nice to have one for (c)!
And I like controllers because of the larger no. of channels (headers), many with the ability to provide more juice than a typical MB header.
But those multitude of channels aren't much good if RPM/voltage can't be captured, & speed can't be adjusted via temp.
If this can't be done in concert with a MB/BIOS/OS, then all this should at-least be integrated into the controller itself.
e.g.
-LCD for RPM/voltage/temp feedback...
-multiple & accurate temp probes...
-12 channels (unlikely) for 'each' fan, so that rpm/voltage can be displayed independently, & fans can be auto-adjusted independently.
-ability set temp thresholds to manage fans/fan-group speeds automatically.
I think there's a few out there that come close to these requirements...
Alas I don't think there's any w/
2x PWM circuits that have the right qualities (not sure what I'm looking for), & enough juice to drive 5400RPM fans.
What I don't get yet - why are you getting PWM fans? If you're getting Scythe GTs, they come in three-pin models. As a matter of fact,
Sidewinder only has three pin models.
Mainly because of the qualities of PWM driven fans, greater efficiency/control etc.
But if it's too tricky to obtain the 5400RPOM 25mm Nidec's from Japan, then I may well end-up ordering 1x 5400RPM Scythe GT.
For the reasons above, I'd recommend giving up a bay to the most attractive fan controller to you and using voltage-controlled fans. If you're going for under-stated and don't like flashy, bright lights, the Lamptron Touch -
reviewed here- is even completely blank (except for the power indicator in the lower right corner) until you power it up. Just make sure you get quality, with good wattage ratings. Watch out for those that look good but are only rated 7W/channel. You seem attuned enough to realize that already though.
I'm not in any rush to move to a discrete controller, if in say 6mth there isn't one that can accommodate "all" my requirements.
Then I may well end-up getting one that does 3-pin fans only...
I'd rather not give up a bay if I can afford it, which is partly why I'd prefer a controller that interfaces with the MB/BIOS/OS.
EDIT - If you really wanted to avoid a bay controller, still get the voltage-controlled fans and you could go with a GUI controlled
T-balancer bigNG that Martin mentioned.
Yeah I think this satisfies more of my requirements (I need to re-list them!) than anything else I've seen yet.
I doubt it'll get much better any time soon
, but I'll be happy with my MB for some time yet.
PWM seems to be the biggest obstacle. If you can avoid that altogether, your options expand quite a bit.
EDIT II - Cleaned up your thread for you.
Yeah I'm starting to think PWM is causing more complication than it's worth.
Just need to determine a few things & if they don't pan out, then I may move toward 3-pin 5400RPM 25mm Nidec's (GT) instead.
Thanks for that!
