- Jan 6, 2009
Just bought this yesterday in the want to DIY myself a water cooling system. 86 Camaro Heatercore picked up at Autozone for $16.99usd. No shroud or mounting equipment, so I must fabricate most of this build. It fits on the top of my Antec 300 with less than a 1/4 inch of case appearing from both sides if your looking down onto the top of the case. This will make it easier to mount a shroud around it. There is not much room inside the Antec 300 to mount the heatercore and I don't want to cut "any" of the case other than where the tubes are going to have to go through the top case panel. However, I don't mind drilling holes in some areas of the sides of the top panel, than tapping them with threads for securing a shroud.
The Antec 300 has a 140mm fan port in the top of the case. I can use the pre-drilled fan screw holes for mounting the heatercore. With a 140mm 3spd fan on top of the heatercore, screws will have to be shoved through the top fan, through the heatercore, through plastic or other martial spacers, through the case fan screw holes, on through the case 140mm 3spd fan, where nuts can be used at the bottom of those screws inside the case. Where they can hide.
I'll have to use some kind of washer between the spacers and heatercore to keep the spacers from crushing the heatercore grills. The fan I want to get for the top is very thin, so it will have a nice low profile sitting on top the heatercore. The inlets and output on the heatercore will face to the front of the case so that the tubes will be able to go straight down into the case. I really don't want much of the tubing outside the case at all. I will be using a 10oz. Stainless steal reservoir and I want that located inside the case as well, it's small and has many places it can go inside my small case. With the SS reservoir next to a fan pushing cool air on it, it would than act as another cooling device for the liquid.
So for now, all I have is the heatercore, the right length of screws and I'll be picking up the black polymer spacers and washers Monday. I can go to the local hardware store and pick up tubing rated at 45 psi in either 1/2" or 3/8" id, but I need to get a pump first before I decide on what tube id I'm going to use.
If you guys have any great links for quality parts(barbs, quick-fit, pressure fit, compression fittings, plastic elbows of 45* & 90*, mounting solutions, loop diagrams and anything I might not have thought of) to aid in such a project, please drop some links... DIY is great!
