- Dec 29, 2000
You make a good point (If I understood what you are saying.) . If one is more tollerant of a hotter GPU, then one can slow the GPU fan to get quiet and then focus on CPU cololing. I didn't make that connection.I understand the quiet aspect but the OP watercooled his 9600 because of two reasons. One was because he OC'd for MORE PERFORMANCE, and second, he thought he needed to keep the temps as low as possible so he increased the fanspeed to 100% which made it loud. Clearly the OP is looking for more performance from his system. Do you not agree that increasing the speed of his CPU will give him more bang than increasing the GPU? Now that the OP knows that GPU's can run at 70C+ for years without a problem, he can turn his fanspeed down to a more bareable noise level and get the most from his CPU.
It's easy to assume someone wants one thing. I was looking at his posts and trying to figure out what he's after. More performance is clearly his objective, with silence along with it. That would make Thors comments clearly relevant. We also have to assume that the OP is not as tech savy as many of us unless he shows it in his posts.
Axis
So this means that in the future all the OP would need is get a CPU block to water cool it. Then put the GPU air cooler back on the video card and run it at a slower speed for quiet but hotter. Then overclock the CPU to get a performance increase. Is that what you'd propose? It's an nteresting idea.
