the whole point i think most should walk away from this thread is being intentionally overlooked ...
...Yeah, 132.8f is not to high of a loaded GPU temp, but to get that temp my GPU fan needs to be at 80%, which is very noisy! I walk into my room now wondering if my PC is on or not! ...
I dissagree. That was not the point of the OP. They did this for quiet not to get the best bang for the cooling buck.
I read that and I understand what you mean. But it is not entirely true. You can make a completely silent cooling system that performs better than fans. Dig a deep hole and put a tank in it. Circulate the water through that for exceptional cooling. But I digress. I don't want to start a flame war as I do respect your opinion and it does apply in general.and this is what i said in my post before. you may have skipped over it but its the unequivicable truth
"performance vs quiet are functions of the same graph"
I, not they, did it for both. For the most part however, I did this for sound dampening. The cooling is just an added bonus. However, decreasing my system ambient temps, I have been able to achieve slightly higher CPU speeds while staying at the same CPU temp. Though, it's just 420MHz FSB.I dissagree. That was not the point of the OP. They did this for quiet not to get the best bang for the cooling buck.
Correct! Though cooling was always part of the reason, the bigger reason was always noise cancellation.That said, I agree that from a cooling perspective you are right. Ans that is a very good point to make for most watercooling. But from a quiet perspective you take the loudest thing and make it quiet. The OP never really said this but that was the direction they went with no real deviaiton.
Personally, I WC the CPU first then NB/SB for overcolocking and finally I may WC the video cards if I get bored. Also for me noise is not an issue as I wear 'over the ear' head phones most of the time.
I've left this PC on now for almost two weeks and I can no longer feel the heat coming from my PC since the liquid mod. Once I get some more project monies I'll get a NB and CPU liquid block.
If you had been standing in my room prior to the liquid mod there would have been two things noticeable, heat -once near the PC- and the noise you would have heard once you entered the room. The third issue I had with the PC, it was warm to the touch. I believe the reason for feeling the heat coming from the PC was due to the PC sitting in the corner of the room on my desk, as the exhaust left the back of the PC and hit the wall the only place it could go was to the left, which was at me. The whine of the constantly cleaned eVGA crap sink & fan was not going to work either and had to go[as previously reiterated]. Now the case is always cold to the touch, even on a hot days ambient temp. I walk into the room wondering if the PC is even on, because it's hard to hear the 5V and 7V modded 120mm fans.then something is wrong, you will have the same amount of heat coming off the pc as with air, just a different manner in how it's removed. i believe the reason you don't feel the heat is because the same amount of heat is being transfered from a larger surface.
e.g. if you have a 100 grams of heat (remember just an example ) coming out from a 1x120x120mm square vs the same 100 grams coming from a 3x120x120mm area it will be less heat in 1 spot.
Hey, I learned something new again!...water cooling doesn't change the amount of heat being removed, just the speed at which it gets removed from the chip.
you got some great results and thats all that matters, Well Done!
the heat in the room should be the same, thats all i'm saying. water cooling doesn't change the amount of heat being removed, just the speed at which it gets removed from the chip.
I understand where you are coming from. But insisting that perfromance and silence are 'on the same graph' is a flawed assumption. That was the point of my example of an in-ground cooling system. You base your response on a limited scope, hence the misunderstanding.that still does not explaine how how silence and performance are not on the same graph.. i dont think you really understand the concept we have been aiming at...
I don't think we need to get in argument here it is not helpful for the OP. But we need to keep an open mind about watercooling here at OCF and not try to force every person into one acceptable method or motivation for watercooling that is couter productive and not fun at all.
Anyway, I thought all of this is supposed to be a fun hobby? So why not do things that are based on what you want to do or what is fun. If it was serious work it would be a job not a hobby.
