- Apr 19, 2010
Hello all, its me again. I finalized my list of components with your help and although I do not have the cash to build it right now, it will be in the near future and I think this build is future proof enough for that. I would like to thank you all for your help and I will post pics in the appropriate topics when it is finished. It is my first water build so I am kind of nervous but I am sure it will be fine.
System Specs:
COOLER MASTER Centurion 590 RC-590-KKN1-GP Black ATX Mid Tower Case
ASRock X58 Extreme LGA 1366 Intel ATX Motherboard
Intel Core i7-930 Bloomfield 2.8GHz LGA 1366 130W Quad-Core Processor
G.SKILL 6GB DDR3 1600 Triple Channel Kit F3-12800CL9T-6GBNQ
SAPPHIRE 100281-3SR Radeon HD 5870 (Cypress XT) 1GB PCI Express 2.0 x16
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM SATA2 Hard Drive
CORSAIR CMPSU-850HX 850W Modular Power Supply
My cooling components:
120mm Scythe SFF21F S-FLEX Case Fan (63.7 CFM/28 dBA) x 6
Swiftech MCR-320 Quiet Power Series Radiator - Black x 2
Swiftech Apogee XT CPU Waterblock
Laing D5 Vario/Swiftech MCP655 Inline 12V DC Pump NOT the "B" version
7/16in. ID (5/8in. OD) Tygon R-3603 Laboratory-Grade Tubing - AAC00033
Probably about 25 feet of tubing because of the double rad setup
and I am not sure how much I will screw up
D-Tek High-Flow Fitting (G 1/4in. Thread, 1/2in. OD) x 4 for rads
Swiftech MCRES-MICRO Rev2 Reservoir
Herbie Clip® Nylon Hose Clamp Size F for 5/8" OD tubing x 12
EK FC-5870 Radeon HD 5870 ATI Reference PCB Design - Nickel
Nuke -Cu Concentrated Biocide (10mL)
IC Diamond 7 Carat Thermal Compound
Anyone heard if the 24 Karat version is significantly better?
My one concern is if that GPU block will fit, it says it is for a "reference card". What does that mean? The only thing I found on google was that there are different versions of the same card. How can I know that this will fit my card before I buy it?
Did I miss anything?
System Specs:
