- Oct 11, 2005
- Tau'ri
Using a mcp 350 with red impeller and BIX radiator. Hve a sanyo denki 120MM fan in a pull configuration using long screws and washers to make a 1/2" gap between Fan and radiator, sealed gap with electrical tape... then use longscrews to mount fan to back of case, also have a 5.25" drive resevoir. All 1/2" tubing.
Running orthos after 2 hours at 2.75GHz 1.4vcore, Am hitting 48C load temps! (actually pulled everything out of case to test this. Idle temps were 28C
I dont think I hit those kind of temps running my little zalman air cooler. Warmer idle, cooler load. Is using the fan in a pull configuration wrong? Is there something else I am missing? Like maybe ditch the res and add a t-Line?
