- Feb 12, 2005
- Michigan
You are right. I totally forgot about that. My bad.
It would be nice though..
I don't think even a 4.5GHz i7 would be able to feed 3x GTX295
you could never have to much power
Time to resurrect this thread
Got the GTX 295 SLI up and running on the i7-920 rig so I will run the same benchies as at the onset with the GTX 280 SLI. Will then do the same with the Q9650.
hello new to this board.
wanted to add my 2 cents
early testing but this is my analysis so far
Dont drink the intel coolaid
i7 is a nice upgrade but not substantial unless you are into synthetic benchmarks, encoding or using multi gpus
I have a q6600 at 3.6
a q9650 at 3.8 (8gb ram) will work on this one, I didnt even have the heatsink properly secured (no backplate)
and now a i7 920 (12gb ram) at 4ghz
my i7 feels actually slower than my q9650 for everyday use.
What i mean by slower (maybe mb bios)
is starting vista sp1 x64 and opening a huge assortment of applications
(word excel ,steam adobe vmware windows 7 , ie mozilla itunes wmc and more)
with my q9650 everything opens without any lag
but with my i7 i see substantial lag
I know this isnt a normal way to test speed.
more of a seat of your pants test.
i would have to say unless you want to drop the cash
stay with a q and wait for the next gen i7s
As was mentioned, unless you're doing alot of encoding or rendering on the rig the gains over C2Q are not great. I am just getting early results from my transition from C2Q to i7 and although the i7 benches really fast the gains in real apps aren't huge...except encoding, which is precisely why I went down this path. 1366 is a monster at HD encoding.
Also the price gap between a respectable s775 rig and a decent s1366 rig has narrowed considerably. I got the Giga UD4P, 3x2GBs DDR3(STT), and i7 920(OEM + stock heatsink) for under $600 shipped from superbiiz...no silly rebates, just good combo prices. Thinking about doing a full review when I have time.
