I've actually downclocked my rig to 3.825 @ 1.26v recently, to see the difference in performance. There is none. But it's running 5C cooler and there's less wear on the chip since the voltage is lower, not that it matters much if my CPU lives for 15 years instead of 13.
All my game benchmarks are the same. The only CPU intensive thing I used to do was video encoding, but now that I'm using a GPU based encoder there's no reason to consider a CPU for that task anymore. In the end it always comes down to what you want to do. If you play Flight Simulator X a lot or do other tasks that heavily depend on the CPU (and aren't GPU utilized yet) then the i7 is obviously unmatched.
4ghz is just a number. I wouldn't mind a Q9550 that I can OC to 3.8 - 3.9 @1.3v or less, when multithreading becomes better utilized and I need a better CPU.
