Well, I got my system put together and man does it run hot!!
I'm using a True 120-Extreme and idle temps are almost 50C. I didn't lap it. Maybe I'll do that, or maybe I'll just switch my WC to this instead.
is there any site that has comparisons for Bloomfield and Yorkfield with Tri-Sli / CrossfireX.
Guru3d had only done that with wolfdale
I will do dual 4870X2's with a Q9650 vs i7-920 early January.
I been reading this thread and it would seem that these new CPU's are faster at encoding rather than gaming... A brand new CPU, and it only can beat it by a few percentage points. Hardly worth the cost of the upgrade. Would this be a correct analogy?
If you are just upgrading the CPU, then No because you'd have to invest in a MB and most likely memory. So the total cost wouldn't justify the small increase that you get, although I think we are just beginning to tap the potential of what these chips can do.
Now, if you are putting together a new system, then it would be worth it imo.
The i920 can be had for $230-250 if you take advantage of the MS live deal. The same can be said for MB. If you went with the old tech, then you'd have to reaplace all that stuff if you ever decided to go with a newer CPU, so you'd be saving month there.
As I posted on another thread,I purchased both for about $460 which is not much more than if you were to get an E8600 and an Asus P5Q3 MB.
the Tri-channel low Vdimm memory was cheaper than when I bought my other DDR3 sticks.
By the time you need a new CPU
January ? Thats 30 days awayBrolloks said:I will do dual 4870X2's with a Q9650 vs i7-920 early January.
The i7 did make a nice difference in Crysis Warhead with the SLI, other than that pretty much the same.
