I cant stop that
BUT any user who are about to flash MUST read the instructions available all over the place, like where you download the bios. Dont flash using remote control. Very easy if you spend 5 min. preparing. One of those things you only have a few problems with once, next time you just do it.
Pretty sure ronin1967 use 2909 cause he is at or above 166fsb, its faster there. Below its the same, use the official. I have not noticed any other changes than what Epox states. From readme.txt
Enhancements & Fixes for this BIOS release:
Added AMD additional Athlon(tm) XP CPU support.
System hang when in 'setup is starting Windows 2000' screen when install Windows 2000 and use ASUS v8420 + Promise TX2000 + Tekram DC395U.
Turn off KB LED after Power OFF.
Fix fan sensor to make system crash issue if the FAN speed result overflow.
Solve UDMA133 option will be hidden.
Update AWDFLASH.EXE version to V8.22A.
Set USB 2.0 item disabled as default.
Update adapt ROM for support High Point 372N.
Previous fixes:
8/15/2002
Solved 3D Mark 2001SE will hang up if APIC enabled.
Report USB1.1 UHCI/OHCI and RAID controller PCI device type.
Added USB 2.0 control item.
Added support to monitor CPU temperature -20C to 100C.
Added for run VGABIOS by item value when resume from STR. Update Clock Control Setting for AMD recommend.
Add new AMD K7 CPUID = 681h support.
Move Sensor code to XGROUP by define `SENSOR_IN_XGROUP`.
btw. be sure you upgrade HIGHPOINT drivers to 2.34 - your bios will be 2.34 and its best drivers/bios share version number. Not that clear info - or I just missed it!
http://www.highpoint-tech.com/372drivers_down.htm
