- Thread Starter
- #21
both still use pcie lanes, the difference is the connector. i am probably wrong but i think u.2 is more for server setups since the drives could be larger in a way then normal consumer drives.
*edit*
so im not sure why you cant trust adapaters, i have used IDE to SATA adapaters they worked fine. nearly ever external HD enclosure uses an adapater to take the drive from SATA to USB/FW.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813995047
http://www.newegg.com/Product/Product.aspx?Item=N82E16813998031
when you got some of the top motherboard manufactures making the adapters, its safe to say they work.
*edit*
not sure how i found this but if you look closely at the connector on this adapter
http://www.newegg.com/Product/Product.aspx?Item=N82E16813995042
this is a sas connector, the u.2 connector sure does look like a sas connector.
Hey Evilsizer, I found an adapter U.2 to M.2 (the one you posted is M.2 to U.2) that is from an unknown maker, that's why I said I can't trust it blindfolded. The only solution is to either wait until U.2 SSDs start getting produced or get a regular SATA drive.
EDIT: http://www.microsatacables.com/m2-to-u2-sff8639-pcie-x4-gen-3-adapter-sff-937-4xgen3
This is the adaptor I was talking about.
