- Feb 24, 2008
- California
Hello everyone,
I have a somewhat beginner question about my current build as it's the first modular PSU I've used.
as the title states we are talking about a Cougar sx 850 PSU
http://www.cougar-world.com/us/products/power_supplies/cougar_sx.html
Under the specs tab you will find the power chart that states 4 12v rails, two @22A and the other two @24A.
http://www.cougar-world.com/uploads/pics/cable_draw_sx850_02.jpg
Here is the cable layout.
http://www.cougar-world.com/uploads/pics/cougar_sx_6_03.jpg
Here are the modular connections
what is getting me hung up is (if you look at the PSU there are 4 red connectors labeled 12v4 and 12v3, and from this I assume both rails 3 and 4 are powering that block of 4 connectors. The unit came with two red modular connectors for PCIe 6+2 pin cables for a graphics card.
The unit also has 2 PCIe 6+2 pin cables hard wired... which from the table above I can assume is powered by 12v2. (as the unit has the block of black connectors labeled as 12v1)
So I suppose my question to the forum is this;
Running dual EVGA 560 FTW+ cards in SLI (each requiring two 6 pin PCIe connections) I have a total of 4 PCIe 6+4 pin cables, two from the box labeled 12v3/12v4 and two that were hard wired from 12v2.
How do I power these cards properly? the two "red" connectors state 24A where the hard wired ones state 22A.
do I a) use both "red" (24A) connections on a single card and both 22A ones on the other
b) Use one 24A and one 22A for each card
OR
c) try to get a hold of 2 more "red" PCIe cables for the second card.... It would seem to me that they built 4 "red" ports so you should be able to connect 4 "red" cables on those rails... however only two were included which makes me wonder if they did that for a reason.
OR
