- Jun 16, 2001
My case has 9 120mm fans and 1 250mm blowhole fan... cooling is not an issue This will be most helpful when I build my 100,000+ PPD folding rig in may
Thats sweet ozzlo what brand case you running?
I'm sorry, I guess I needed to clarify, the contest is over, the final winners will be announced before superbowl.
Keep me posted, ozzlo. I want to get the official results on the front page.
I finally got the prizes boxed up and comp is runnin on the 4350 now. Sorry for the holdup, I had to get creative with packing the GTX 260 as I don't have the original box anymore
I couldn't find the driver disc for the 5870 (the drivers on the cd were pretty worthless an outdated anyways...)
all original manuals and materials with the 260 are long gone, I threw in a spare DVI -> VGA converter as I think it came with one of those.
Prizes ship out tomorrow morning.
Sweet!
I was looking on how i was to install the 260 in my comp and i think i might have to make a mount for the water pump to hover about mid way up in the case to fit everything. Know all i have to do is find the power cable converters... the ones that connect two HD power cable to one 6 pin for the vid card. I have one that came with the 275 but the other is missing in action.
Just got mine in....Thanks very much this sucker is amazing getting ready to eat and install it. Will post pics/thread/benchmarks once all drivers and files are cleaned and installed.
**EDIT**
Well guys I'm sorry to say this card is going nowhere fast till I can get a larger PSU this 600W just doesn't have the balls to push it and wow the 700W - 1000W PSU are sky high. Anyone out there that would have input of needed wattage to run a 5870+ first rig in sig. It is much needed as I see it now I'm looking to drop almost $200 I don't have to get this card running.
[FONT=verdana,geneva]The card requires you to have a 500 Watt power supply unit at minimum if you use it in a high-end system. That power supply needs to have (in total accumulated) at least 40 Amps available on the +12 volts rails.
I got a sweet deal on a 1000 Watter which is why I gave away my 650 watt PSU in the contest. In other words I don't really know the minimum wattage as I never tried it on the 650.
a review I once read on the card stated as follows...
[/SIZE][/FONT][/COLOR][/SIZE][/FONT]
it's also possible the card may be pulling more power than the board circuitry can provide, I would research comparability with your mobo especially if it's old.
