- Jan 19, 2004
- Tennessee
...for it SLI's no more.
A couple of years ago I set up the following configuration:
160GB Intel SSD
3 TB HDD (2 drives)
8GB RAM
2x 580GTX 1.5GB RAM SLI (MSI Twin Frozr coolers)
i7-2600k
1200w PSU
Over time, performance has waned. It was partially heat; even with cleaning out the fan filters on my case I found myself clocking the cards down ever more toward their factory settings. Bioshock Infinite finally took me the rest of the way down because any OC at all caused stability problems.
One of the cards was never as stable as the other due to a damaged resistor thanks to a clumsy (now ex) girlfriend I had at the time. No, that's not why she's an ex, but it didn't help her case. I had been able to run both cards for quite some time, however, until recently. During a session of Dead Island Riptide, however, my computer crashed like Courtney Love on a Monday morning. After that, anything that spiked GPU usage blackscreened me.
I removed the cards and this time, instead of "standard maintenance", removed the heat sink and fans to discover that of my 2 cards, only one still had fans that would rotate. I tried cleaning them out, greasing them, etc. but of 4 fans, only 3 of them were spinning. I then tried so hard to repair the 4th fan that I broke it and had to clip it off. I tried running with 3 fans but the card with the gimped cooler was also the one my ex damaged, and any hope of functionality was gone. I'm relatively certain that thing is a brick now. In another PC it doesn't even detect as a video card.
Now I'm down to one 580GTX. One of the two fans is limping along and the other is now making a sound like a bumblebee trapped in a tin can if I run anything. We're talking STO, jMonkeyEngine, OGRE3D, stuff that doesn't exactly bring a fully functional 500 series to its knees. I can probably buy a new cooling system, but I game largely in 3D and have already discovered that 3D is very demanding on newer games. Going down to one GPU has really hurt me, at least from that generation. So, I'm thinking maybe it's time for the Next Generation
My options are:
1x 780 GTX - 3GB of RAM and raw power are very attractive. Price approx $650 USD. Wife approved getting it a twin once I get the card paid off from that purchase.
1x 770 GTX - 4GB of RAM for only $450 USD, but I'm concerned. While this will definitely outperform a 580 in terms of raw power, what about that memory bus? I'm enjoying 384-bit interface as is and the 770 drops down to 256-bit. At 256-bit, would I really see my super-high-resolution texture mods for Bethesda games use that extra memory, or would I really see a difference between that at the 2GB variant? This, also, would get wife approval for a second one down the road.
2x 760 GTX in SLI- 4GB of RAM again since the 4GB variant is out, but the same 256-bit interface as the 770. At around $560 - 600 for the two together this is probably the most cost effective, but the same questions arise over memory as do with the 770. Another issue here is that I'm limited to Amazon financing at the moment, and nobody seems to be carrying the EVGA or Gigabyte 4GB 760GTX there.
As I limp away on the beehive in my rig, I find myself dealing with complete marketing overload. I don't know what to buy. Help!
Edit: For those unfamiliar, 3d means I'm gaming at 120hz not 60 for my refresh rate. I also am frame-sensitive below 42 FPS and find 30 to be too slow. Also, I sometimes output to a 55" TV as well as my monitor. Both connections are no higher than 1080p resolution, and only the main monitor is used for 3D.
160GB Intel SSD
3 TB HDD (2 drives)
8GB RAM
i7-2600k
1200w PSU
My options are:
